Something wrong with it then.. The air in a truck holds the brakes off until you press the brake pedal. Some air pressure is released and the brakes start to come on. more you brake more air is released..
Trucks are not limited to 60mph. It will do whatever spped you let it down hill until you apply either the foot brake or exhaust brake.. Even on idle the brake compressor is working building pressure and at revs it should be able to produce more than enough even under heavy braking..
As I've already said:
"You can free wheel down hill to any speed gravity and the engine breaking will let you in a lorry (because they still rev as if you are doing 56mph and in top gear). "
Brake compressors are gear driven, the volume of air they supply is entirely dependant on engine speed.
At idle they wont supply enough air to keep the tanks charged as you know already if you make continued demands on the air reserves.
Thats why, even in the latest mercedes gearboxes which they say you can "free wheel" down hill to save fuel, you arent, it just automatically changes gear to use engine breaking to keep you at the set speed, because "free wheeling" in an HGV, is a spectacularly bad idea, because you are not running the compessor.
