Current 120mm rear exhaust fan recommendations?
Depends what you're looking for
Rgb,no rgb,one that can chain to your other fans
Or best cheap one
Or best expensive one
There's quite a few reasons to decide which
Fan to recommend
Or best cheap one
Fan to recommend
Good point.
In that case, I have no interest in RGB.
I think my priority is silence.
Well that at least rules one thing out
Silence will depend what rpm you spin it at
Just about all fans will be very quiet
Up until roughly 1,000 rpm
So how much air you need to exhaust will affect
The rpm level
What make and model are the other case fans?
And are you happy with those ones?
Edit
Cheap recommendation
Artic p12
Expensive recommendation
Phanteks t30
Thicker 30mm fan but usually extra 5mm is OK
At rear of the case
