DELETED_5350
Once you've installed ESXi and given it a management IP, you can use your browser to connect to it. From there it will have a link to download the client that was previously mentioned.
ESXi is very simple stuff - it holds your hand through most things. Once you have it installed you'll be zipping around it in no time.
Your plans look fine.
Post your questions in here - lots of knowledge and you won't be waiting on one person to answer
yes :)
oh and if you are contemplating NAS duties for it (which is perfectly fine) I suggest to look at data recovery from you VMDK's before you leap all in. It is not tough at all, just slightly more complex than putting it into a usb caddy and copying your files off. It's all learning - which is good!
Nox
