Hi,
I've just picked up a R410 with an X5550, iDRAC Enterprise and redundant PSU (plus perc 6/I) for dirt cheap here in NZ. Whilst it will be in a rack and well away from living areas in my house it sounds like a jet engine at all times, apart from momentarily on boot when it actual doesn't sound at all bad. I'm just about to do a full update on the firmwares as they're all out of date so I hope that might fix some of the issues.
My question is this: What is the best power management mode for running ESXi on so that the fans reduce to their lowest setting? Also, I've read that removing the perc may reduce the speed of fan #4 so will try that and get a SAS 6/r to replace it as I do not have any sata power cables for this unit.
Any pointers greatly received.
Chris
Chris
