I want to prove a point at work that our database server is being seriously held back running nearline (7.2k) HDDs. I need 1TB of space to do it, and it needs to have a level of redundancy for even a test as it will be live (so all the normal users pushing it to prove it).
So my thoughts are to try and get the OK to buy a couple of 1TB consumer SSDs, put them in caddies and get the people who run the server for us to configure them into a RAID1 array and then move the client facing VM onto them.
But I don't want to spend £600 on SSDs that the server refuses to use. Host system is Hyper-V server 2012 running 2k8 VMs. Two years ago I asked the DB provider if the drives were holding us up - and NOW they've tried to tell me the same thing
The other VMs run background generating tasks so can essentially take as long as they like - it's the client facing server that needs a rocket up its behind.
If I can prove a massive performance increase, getting the budget to put enterprise grade SSDs in would be relatively straightforward.
