Desire calender help
25 Jun 2005
Can't find any help on line or that work anyhows.
I'm running ginger bread and made myself a googlemail account to use and keep altogether. I made the account as I set my phone up.
I'm trying to add my googlemail account to my calender so it all syncs up but when i try to add a calender the option to add is greyed out.
In fact the remove is greyed out.
Any ideas?
As an addition I've now got thunderbird sync with my googlemail calender with the thought that I can use HTC sync to get the phone to sync with thunderbird's calender but calendar and people are greyed out in it?
Regarding your first post, what happens when you make an appointment? By defaut your calendar should automatically sync.
Go to Settings > Accounts & Sync.
Tap on your account or add it if it's not in the list.
Then next to "Calendar" is the checkbox ticked?
If yes your your calendar will be synced with Google's servers.
Any changes you make on your phone will be immediately synced to Google's servers, and any changes you make on your calendar through their website will be synced to your phone.
You are talking about the Google Calendar App right?
Can you be more specific when you say "I'm trying to add my googlemail account to my calender"
You'll be much better off to use the calendar already associated with your gmail account and add things to that...
