at dual prime load im stable for 25 n half hours, no errors. Just put a 60mm akasa fan blowing over the pwm area. Played COD4, 5 mins and locks up. Upon rebooting i check temp in bios and was at 41c.
It crashes at my current overclock, even though prime stable and when at stock![]()
Just noticed you are running a 3870x2. There are known issues between the 3870x2 and the X48 chipset, lockups and reboots being among them. It's not just a DFI issue either, all the different X48 mobos have problems with it of one sort or another. If you have another GPU, try it, just to confirm it is the 3870x2.
