I have no experience with the jumper config but if all down makes the lower PCIe slot a 16x slot and the top one a 1x it should make no difference.geeza said:Does the moving of my graphics card to the lower pci-e slot make it run any slower. I have moved all 6 jumpers a notch down too?
Chris19 said:I seen on the theread about the Ultra-D/Sli DFI boards that the top Pci-e hole is faster and that the yellow Ram holes are better than the orange ones.
Chris19 said:yellow Ram holes
By default, the jumpers are configured to route 16 PCI Express lanes to the first x16 slot, two lanes to the second x16 slot, and one lane to each of the x4 and x1 slots. The jumpers can be switched to route eight lanes to each of the x16 slots and four lanes to the x4, effectively disabling the x1 slot. Unfortunately, that's the only way to get four lanes to the x4 slot—the board can't be configured to route 16 lanes to the primary x16 and four lanes to the x4 at the same time.
Gaverick said:My X1800XT reaches over the chipset cooler, with about a 6mm gap between the cooler and bottom of the card.
