Diagnose a friend's problem (Mk3 Golf)
31 Oct 2002
Newcastle upon Tyne
Friend just asked me to have a look at her car.
You turn the key and it starts but as soon as you let the key return to it's normal position the car cuts out. If you keep the key turned the car idles fine (when the starter motor would normally be screaming)
You can't even start the car and give it some revs to keep it going.
Any ideas?
on those mk3s, if the immobiliser is upset you get a symptom where the engine will turn, it will fire and then it rill run for about 1 second and no matter what you do it will cut out
vagcom will tell you what the immobiliser has been doing
