1. Advancing the ignition does not give you more power unless you are doing it to use a higher octane fuel in a petrol car.
2. Diesels until recently use auto ignition, which cannot be re-timed. Some of the high pressure injection engines inject the fuel at the point of firing/s, this could be altered, but there would be no advantage to pre-ignition.
Changing the injectors can increase bhp, I got 30bhp more.
How? and what car?
In Diesels - The fuel is what gives power - So if you chuck in more, it will give you more power.
And air, n'est pas?
No...as Rover416i found out when he 'tuned' his diesel Rover, it belched black smoke and gained about 5bhp...he'd also cranked up his turbo...and then blew a turbo hose ~30mins later.
Fuel is what gives all car their power. :/
