Difference between Asus P5WD2 Premium Asus & P5WD2-E Premium Intel
26 Aug 2004
What is the difference between
Asus P5WD2 Premium
Asus P5WD2-E Premium Intel?
I want to put a Pentium 4 Dual Core 920 2.8 ghz in this. Will it overclock well in this mobo? I heard someone got it to 5 ghz on air!!! Does this processor work with 64bit software, is it a 64bit cpu?
Thanks for any help. :D
24 Dec 2004
Knowle, Solihull, UK
The P5WD2 has the Intel 955X chipset; the P5WD2-E has the Intel 975X chipset
The main difference is that the 975X chipset supports crossfire, although apparantly they're adding this to the 955X range (albeit with one slot at 4x)
The chips have the 64-bit extensions so they will run x64 software
