Devious said:
Durzel, you seemed to be having some problems with your P5W64 on XS.
What did you do to 'fix' it and what do you think the max FSB with ax9 multi would be ?
I couldn't Clockgen over 410 when I first started, this was with the original BIOS. Basically the same problem as I had with the P5W-DH, which wasnt a nice feeling having just spent out nearly £200 on the board
I've only been booting it at 410FSB so far, then Clockgen'ing it up to 450 in Windows. This is mainly because I think the board initially POSTs with the original multiplier before changing it... there's no way I can POST a E6700 on air cooling at 4.5Ghz. This is my hunch anyway.
Also - vCore seems really important to high FSBs. I can't POST the board
at all at 410FSB regardless of multiplier (even 6x410 - 2460Mhz) unless I give it 1.4250v vCore, which was enough to dual Prime at 3.6Ghz on the P5W-DH. So, it definitely doesn't need that much vCore for the CPU speed (which is actually underclocked!), but it seems to need it for the FSB...
Problem I've got now is I don't want to stick too much volts through my CPU while it's on air, I have a feeling it would need 1.5v+ to boot at get more than 450. Once I get it under my Vapo LS I won't care about sticking 1.55+ through it, then we should see some interesting results. The fact it needs much higher than required vCore to POST also suggests that it's booting with the standard multiplier before changing it down to whatever you set it in the BIOS.
As for max FSB? Until I get it under my Vapo, or get a CPU with a lower multiplier (for the POST) I won't know... the person who got 500FSB (Clockgen'd) on XS had stuck 1.55v through their chip, which with overvolting on this board would've been more like 1.625v in Windows... too much for me on air.
Aiming for 10x450 bootable really, anything more will be a nice bonus.
