I'm thinking its something like kopex you are trying to draw through: https://www07.abb.com/images/librar...s/pma-ex-system/396px-width/kopex-exb_396.jpg
If so then because its ridged inside then you might struggle I think!. One thing that does seem to work well (and I'm not sure what you'd get in lisbon thats similar). is strip the brown or blue out of a bit of 2.5 twin and earth and bend the end over, that gives a smooth end which can glide over the ridges, if its not ridgid enough then just strip the end of the twin and earth for a few inches and do that to one of the cores and then tape it where it comes out of the stripped end of the cable
