dirt 2 win 7 xfi hardware audio problem
21 Jul 2005
hello,
just bought dirt 2 from steam (£15!) and installed it on a fresh win 7 install, has anyone noticed that when using hardware audio mode certain sounds cut in and out? things like the engine sounds and collision noises?
well im glad no one else has this problem, either way if you do encounter this try backing off on the overclock or upping the voltage on the mem a touch, either way has worked for me
thanks
