Hi there
We've added several more new Sapphire cards to the range and they all have Dirt 3 Coupon bundled inside the box (whilst stock last):-
Sapphire ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 Game @ £269.99 inc VAT
The Sapphire HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters Supplied)
- 500W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Mini-DisplayPort too HDMI Cable
- Supplied with 1.8M HDMI High Speed Extension Cable
- Supplied with Dirt3 PC Game (Subject to availability)
Only £269.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 FLEX 2048MB GDDR5 PCI-Express Graphics Card with upto 5 Monitor Support & with FREE DIRT3 Game @ £229.99 inc VAT
Most graphics cards based on AMD technology require the third monitor in an Eyefinity set-up to be a DisplayPort monitor, or connected with an active DisplayPort Adapter. The SAPPHIRE FleX family can support three DVI monitors in Eyefinity mode and deliver a true SLS (Single Large Surface) work area without the need for costly active adapters. The first two monitors are connected to the two DVI ports and the third to an HDMI to DVI cable (supplied) with no extra hardware required.
The SAPPHIRE HD 6950 FleX is now the highest performing card with this feature, allowing gamers to use low-cost DVI monitors for all three screens. Additional monitors can be added to the setup, but must be DisplayPort connected.
Like the standard HD 6950, the SAPPHIRE HD 6950 FleX Edition boasts true DX 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. With its clock speeds of 800MHz for the core and 1250Mhz (5 Gb/sec effective) for the memory this model brings multi-screen enjoyment to even hard-core gamers.
Features:-
- Core Clock: 800MHz
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1x Dual-Link DVI-I, 1x Single-Link DVI-D, 1x HDMI 1.4a, 2x Mini-DisplayPort & DisplayPort 1.2
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Support 3 DVI monitors in Eyefinity mode, right out of the box! Up to 5 monitor Eyefinity mode support with Sapphire Flex.
Only £229.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 Game @ £214.99 inc VAT
The Sapphire HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £214.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 1024MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 Game @ £187.99 inc VAT
The SAPPHIRE HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Memory: 1024MB GDDR5
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £187.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6770 1024MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 Game @ £94.99 inc VAT
Now, more people than ever can experience real innovation in DirectX® 11 gaming with AMD Radeon™ HD 6770 Graphics. Expand your visual real estate across up to five displays and get lost in the action with AMD Eyefinity multi-display technology. Using AMD App Acceleration, speed up everyday applications and do more than ever with your PC. Loaded with advanced technologies, these GPUs have the power and premium features needed for fully immersive gameplay.
Features:-
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 800
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI 1.4a & 1x DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 2 Years
Only £94.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6770 512MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 Game @ £83.99 inc VAT
Features:-
- Memory: 512MB GDDR5
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £83.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6570 Ultimate Edition 1024MB GDDR3 PCI-Express SILENT Graphics Card with FREE DIRT3 Game @ £64.99 inc VAT
The HD 6570 ULTIMATE from SAPPHIRE features a single slot low profile card with silent heatpipe cooler. With its 480 stream processors, engine clocks of 650MHz and 1GB of DDR3 memory clocked at 900MHz (1.8GHz effective) this is an ideal solution for HTPCs or general purpose PCs where silent operation is an advantage. Outputs are HDMI, DVI-D and VGA.
The AMD Radeon™ HD 6570 graphics processors offer advanced video and display features, as well as 2nd generation support for DirectX 11 to offer the ultimate in versatility for the everyday computing desktop.
Features
- Fanless Silent Design
- Core Clock: 650MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1800MHz (Effective)
- Processing Cores: 480
- Display Connectors: 1x Dual-Link DVI-I, 1x HDMI, 1x D-Sub
- HDCP Capable
- ATI Avivo HD
- Dimension 169(L) x 19(W)x94(H) mm Size.
- Warranty: 2 Years
Only £64.99 inc VAT.
ORDER NOW
Features:-
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
