any one has one fitted to a ddc pump?
I'm having issues with stock pump. It does not pump until a few seconds after post. I have increased post delay in bios to max but I still get cpu fan error when booting and I have to wait watching bios screen to see the pump has started.
I was wondering if the pcb would sort it or if there's anything else I can do or try?
i replaced my old 10watt ddc which was doing the same but a year and a half of it been working perfectly. I thought it was dying so I replaced it with an 18watt, that worked fine for a few months so I rma'd and the new ones doing the same.
I also have a pump res combo from an ek kit that works without issue I have thought about add that to the loop to the mobo header and power the ddc from my aquaro 5. Basically I want the ability of bios giving fan error/shutting pc down if the pump fails.
Any thoughts, opinions or advice?
