Specs:
7700k
Asus Z270E
1080ti FE
16gb 3600mhz darkpro
Machine has been running without issue for around 12 months.
Problem:
When booting the machine the PC will randomly loop back to the bios or just keep switching off & on. Sometimes it will just sit there with the fans running until I power off at the mains.
Tried with & without any overclocks, flashed 3 different bios with no change.
Also replaced the battery in motherboard.
When finally getting the PC to boot it runs fine until I either switch off or restart.
If I restart the PC, it enters a continuous loop where it turns itself off & on. Only way out is to switch off at mains & reboot.
The other thing I've noticed is when booting up the monitor screen will flicker rapidly several times before either entering the bios or starting windows.
I've spent the several hours tonight flashing the bios trying different ones & settings & at the moment it's running ok, but I'm unsure what is causing these issues.
Any ideas would be appreciated.
7700k
Asus Z270E
1080ti FE
Problem:
