Where’s that Chinese memory we were promised? I really want them to flood the market and wreck these companies who are abusing their monopoly.
They are more expensive.
You can think of it the same way people think in video games, the goal is to optimise the game playI would guess that the cost of building data centres is not a "operating cost", but that's the really expensive bit. Creative accounting at its best.
absolutely wild rightYes I bought mine about the same time, cost me £228 and it's now over £1200
Can't beat em join em haha you have 3 sets of the ram there basically hahaBought 96gb ddr5 laptop ram for £270 in Dec 2025, currently sitting at £1599 to buy again :O
Hi there
Consider this a headsup for forum members and your last chance!
Next week OcUK shall start it's Black Friday promotions and Tuesday onwards we shall feature one or two "Lightning Memory Deals" this will see 32GB 6000MHz low-latency kits back sub £400, but as they are "Lightning Deals" the website shall promote these and they are capped quantity wise and also on a 24hr time limit.
I can assure you we won't do these deals any cheaper, I also suspect by 2027 we will struggle to offer any 32Gb kits for under £500 possibly, so £399 for a CL28/CL30 6000MHz 32GB kit in current climate is a market beating deal and is probably the best you will find globally, the deals are 1pc per customer and limited to UK only.
It is your last chance for a sub £400 kit, starting next week from Tuesday, sad times that £400 is a deal but that is times we live in but at least OcUK is doing a superior job to its competitors on memory and bringing deals and been competitive if not cheapest.![]()
I never thought that I would wonder how sustainable itis for a retail
Is there any reason why these kits, and brands, tha tseem relatively new have support for EPO settings and not XMP, typically Intel settings for their timings..? I can't remember specifics now but one of the sets suggested not being compatible with later gen Intel's.
Someone posted, again sorry for the vagueness, that they had a lot of issues with using one of the more affordable brands with an Intel based system.
Are they more guaranteed to work OOB with AMD, rather than needing manual timings for other CPU flavours..?
All the best
Our focus is EXPO and EXPO ULL simply as it is now majority of sales.
Anyone buying for Intel should not be buying an EXPO kit ideally as the IC configuration can be in compatible with some Intel platforms, for Intel it is best to focus on XMP SKU's, the problem is as Intel solutions are becoming the minority now, they cost more because are not as mass produced.
If they're excluding Core Ultra, then the sticks are likely double sided in 16GB capacity (or can be, depending on the chips used).EDIY: Noted a number of KLEVV now listing XMP's for Intel, perhaps the oddity being...
Well you don't need DRAM because the data centres need it more (according to Altman) ;
"Appearing on a recent episode of the Cheeky Pint podcast, Altman argued,
"From a global allocation perspective, actually it’s quite terrible to have everyone have a bunch of the world’s limited supply of DRAM sitting in their own computer, and be used 5% of the time."
Altman is wrong
Of course, PC memory isn’t used only for running AI models. Games, browsers, operating systems and professional applications all need RAM, even when users aren’t actively using them. Local AI also gives users the option to run models without sending their data to remote...
Source: VideoCardz.com
OpenAI CEO Sam Altman calls PC RAM a "quite terrible" use of limited DRAM supply - VideoCardz.com
Sam Altman says cloud data centers can make better use of DRAM than personal computers running local AI models. His comments come amid continuing memory shortages.videocardz.com
This is what I'm struggling with, I currently have 64GB DDR4 with a 5950X, but 10800x3D (or whatever they end up calling a 12c single CCD) is the chip I've been waiting for.... toying with the idea of trying to buy a 32GB kit in the flash sales and maybe get a 7600 to tide me over, but what if 32GB isn't enough for a lot of games by the time the new CPU comes out?I agreed Altman is wrong, he is completely clueless. When I had PC with 32GB RAM 2 years ago it struggled at around 90% memory usage with only browsers opened and played a game. Now I used 128GB RAM it ran much better and smoothly at 50% with browsers opened and played a game.
Altman can GSYM!!Well you don't need DRAM because the data centres need it more (according to Altman) ;
I priced up an AM5 based EPYC system with a 4545P to replace the first gen Ryzen system I'm currently using and DDR5 ECC UDIMMs would start at 3k quid for 64GB. And that's being generous at 1500 a stick of 32GB. Some of them are going for nearly 2k a stick. ECC has always been more expensive than regular RAM, but the rise in cost wasn't a curve so much as a wall.Looks like I'll be staying on AM4 for the foreseeable...
