** DREAMHACK MONITOR SPECIAL **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
DreamHack CS:GO Championship - DreamHack Winter 2014 is currently running with nearly 150k unique watchers in just the group stages.
http://www.twitch.tv/dreamhackcs
The Teams are all using the EIZO Foris FG2421 Monitor in the competition.
240Hz and 1ms response makes this the fastest response mon on the planet.
We have stock of these on sale for Black Friday so why not take advantage whilst the price is low.
EIZO Foris FG2421 23.5" 240Hz Widescreen Gaming LED Monitor - Black/Red @ £289.99 inc VAT
Experience fluid gameplay free from motion blur with the gaming industry’s first 240 Hz monitor. EIZO’s Turbo 240 converts 120 Hz input signals to 240 Hz for a refresh rate double that of conventional gaming monitors so you can enjoy the smoothest motion display yet for first-person shooter, racing, and other fast-action genres.
Input lag, or the time it takes for commands from a keyboard, mouse, or controller to appear on the screen, can be the difference between hitting your target and missing it. EIZO developed its own integrated circuit to ensure your commands appear onscreen without delay.
Play like the pros with gaming presets from pro gamers such as Counter-Strike legend Patrik “cArn” Sättermon and Dota 2 player Johan “n0tail” Sundstein. Use the bundled software, ScreenManager Pro for Gaming, to download these and other presets from gaming.eizo.com or to export your own presets.
The FORIS FG2421 uses a new VA (vertical alignment) panel with a native contrast ratio of 5000:1. This is 5 times more than what other gaming monitors offer and increases the visibility in dark scenes so you can spot enemies more quickly.
The rear cabinet design features an LED backlit EIZO logo on a glossy surface surrounded by a vermillion frame. The logo glows brilliantly in a dimly-lit room or in a tournament setting. The front cabinet has a simple design so you can focus on the screen.
EIZO’s five-year warranty is two years or 67% longer than the standard three-year warranty of most brands.
Specification:-
- Panel Type: VA
- Size: 23.5" / 59.8cm (598mm diagonal)
- Native Resolution: 1920x1080 (16:9 aspect ratio)
- Display Size (HxV): 521.3 x 293.2mm
- Pixel Pitch: 0.272 x 0.272mm
- Grayscale Tones: 256 tones (a palette of 1021 tones)
- Display colours: 16.77 million from a palette of 1.06 billion
- Viewing Angles: 176 / 176
- Brightness: 400cd/m (Turbo 240: off)
- Contrast ratio: 5000:1 Typical (15000:1 with Contrast Enhancer)
- Response Time: Less than 1ms (Turbo 240: ON, Monito spec)
- Connections: 1x DisplayPort, 1x DVI-D (with HDCP) & 1x HDMI
- USB Hub: 2 Ports
- Power Saving: Less than 0.5W
- Standby Mode: Less than 0.5W
- Stand: 60mm Height adjust, 25 degress up tilt and 344 degrees swivel
- Dimensions: 563.5 x 391 - 451 x 200 mm
- Weight: 6.2kg
- Warranty: 5yr
- TFT Central Review: http://www.tftcentral.co.uk/reviews/eizo_fg2421.htm
Was £329.99 Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
Nice Monitor!
Got a feeling these will sell well.
If I hadnt upgraded at the start of the week id be all over this! Never has the back of a monitor been so nice :cool:
