Hi all,
My shiny new wheel arrived recently & I want to get the best from it.
I've only had time to drive a few laps and it wasn't bad but needs a little work. Does anyone have any setup suggestions? I've found quite a few G25 setups but not so many for the DFGT.
What a different experience though, I've been a contented keyboard driver for years so this will take quite some time to get a feel for! Initial impression is very good though...
- Whats a good amount to set for the 'degrees of rotation' in the Logitech profiler? I've seen some suggest 340 and others 900.
- In Shift, I'm a little confused what the difference between 'Combined' and 'Seperate' pedals in the DFGT setup menu. Is this something to do with having a clutch or not?
