Dual LAN help please
3 Apr 2006
Hi,
My company have installed a new phone line with broadband in my home office and I am now using that for work - via a router using wireless to my laptop and same router via an ethernet cable to my desktop.
I have kept my "home" phone/broadband account and have moved that to a cheaper tariff - because my two teenage boys are using that for WoW and who knows what else! They are wired into the old router for that and I can plug into that as well with my desktop - which only has one LAN port - Asus P5B.
My question - I would like to access the internet via my work router but would also like to have a second network that allows me to share a USB printer attached to my desktop and also share some file space on my desktop with the kids. I have a PCI network card somewhere and am running Vista 64. I am not sure how to have two separate networks on one PC and make sure one goes to the internet (although both networks have that capability)? Any pointers?
Easiest way would be to set your home network connection to use a static IP and remove the gateway or DNS settings.
Complicated way would be to adjust the routing tables.
