Long time no post. Hoping to get some opinions from some mechanic minded people.
I had to replace a crank seal on my daily. Car went in the workshop fine and the seal was replaced. The mechanic built it back up and tested it and now there is a rattle which he thinks is the flywheel.
I know these give up and have problems but is it likely to fail because it was removed and refitted ?
there was no clutch or flywheel issues at the start, just the oil leak. A mate who is a mechanic thinks it’s unlikely and could be the release bearing not seated properly.
any thoughts? It’s a 1.7 cdti Astra
