Back again
Right the celeron d processor (Dual core 2.66ghz) Was running at 47 degress idle and 53 degrees loaded
I overclocked it by 5% so its now at 2.79ghz/2.80ghz not sure why one core is slightly slower but hey,
Now i had the choice whether to allow my MOBO to overclock it and change settings automatically or whether i changed then my self.
I upped the fsb by 5% and booted into windows. I have passed the SP2004 tests but temps reaching 60 degrees loaded??????
Any ideas or how to get that coller and does my idle temps sound right? If not could it be i have a dodgy chip?
If its ok how far can i go and should i let my mobo overclock it for me?
Thanks
Shr3k
Thanks
Shr3k
SPEC ME
