But on mine I use the Digital CD Audio cable to hook it up to the CD_SPDIF port on an Creative Audigy sound card.
hp7909 said:Digital CD Audio Cable (2-pin)? or Analog/Analogue CD Audio Cable(4-pin)?
Don't know if you still need to use it though on a modern PCBut on mine I use the Digital CD Audio cable to hook it up to the CD_SPDIF port on an Creative Audigy sound card.
Note: If connecting to a motherboards Internal Audio Connector, most are Analogue 4-pin type only.
hp7909![]()
What software are you using? & any chance its set to Use SPDIF under Audio Options?JoeBoi said:Well when I play dvds I have no sound could be a driver issue maybe, if it helps I have a LG dvd/rw drive. I do have a 4 pin cable that clips in, it also has some funny little white cable attached to it.
