E60 535d - Chirping / 'Crickets' noise from engine bay
Man of Honour
17 Oct 2002
Retired Don
Hi guys,
My car has suddenly developed a sound from the engine bay, which kind of sounds like and has the same rhythm and the sound that crickets make!
Anyone got any ideas what it may be?
Thanks,
Mal
22 Nov 2006
It's the fuel pump, I had this exact problem with my GT86 (pretty common on the 2012-2015 ones) until it was replaced under warranty.
22 Nov 2006
It might not actually be a problem, just annoying. With some certain fuel causes it and others don't, so it may go away after filling up again.
This is the sound right?
Man of Honour
17 Oct 2002
Retired Don
Bit of a development on this one!
This morning I heard a pop and then steam coming from the bonnet and the coolant light came on.
For breakdown out and they said it's the auxiliary belt and the water pump. The pump bearing had probably gone and seized, and shredded the belt.
Getting it sorted early next week - hopefully it's nothing else!
Mal
Caporegime
25 Nov 2004
On the road....
Mal
What’s the sod’s law likelihood that once the belt & pump is fixed the noise remains? :D
1 Mar 2010
How did you select the garage for the recovery tow - where you have had work done before ? or BM themselves,
I always mean to find a regular servicing garage close to home, as opposed to work, say.
hope it's just the pump - (maybe a bmw plastic vs metal impeller dilema, like e36 used to have?)
