Hi all,
I've justing finished test my first real overlcock and would like some advice on my results and if there's anything else I should try. I'm really happy with the result and increased my benchmark scores by 35%.
- Abit IP35 Pro motherboard
- Core Duo E6750 CPU @ 3.6GHz (450 FSB)
Vcore @ 1.4175 v
- Crucial Ballistix PCS-6400 RAM @ 1.08 GHz (on 1 : 1.2 ratio)
DDR2 @ 2.25 v
- 8800GTS at stock
The idle temps are 31c and 33c and at full load these max out at 64c
Just wondered whether it's worth trying to push the processor or RAM a little further? Are the temps alright?
The next step will be to overclock the GPU but I just wanted to max out the CPU and RAM first.
Thanks in advance.
Vcore @ 1.4175 v
DDR2 @ 2.25 v
- 8800GTS at stock
Thanks in advance.
