** Edifier - Unparalleled Sound Quality ** Buy Now!
20 Jul 2009
The bleak North East arm pit of Britain
Edifier as you are probably aware are pretty unknown in the UK however do not let this put you off. Take a look at the 4 lines stocked by OcUK and let me know what you think. The OcUK purchasing team all agree that these scream out quality and the sound quality when compared to other brands on the market is exceptional so take a look at the following lines as they really are that good! :D
Edifier R1600T Studio Plus 2.0 Monitors. @ £69.98 inc VAT
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
Only £69.98 inc VAT.
ORDER NOW
Edifier E3350 (Prisma) 2.1 Speaker System @ £68.99 inc VAT
An audio and visual delight, the Edifier Prisma speaker system is a treat for your eyes and ears! The exotically shaped subwoofer and satellites are designed to complement modern PC and monitor styles, while the matt black finish will suit contemporary homes. A wired, low profile volume control with red halo effect means the makes adjusting the volume easy, and the built-in headphone and MP3 jacks offer flexible listening options.
- Power Output: RMS 2 x 9W + 32W (THD=10%)
- Signal to noise ratio (amplifier) : =>85dBA
- Distortion: <0.5
- Input Sensitivity:
- R/L: 550 +/- 50 mV (Line-in), 300 +/- 50 mV (AUX)
- SW: 200 +/- 50 mV (Line-in), 100 +/- 50 mV (AUX)
- Frequency response:
- R/L: 190Hz ~ 20kHz
- SW: 30Hz ~ 130Hz
Only £68.99 inc VAT.
ORDER NOW
Edifier S330D 2.1 Speakers 72 W RMS Sound System @ £109.99 inc VAT
Designed for the home PC gaming and music fan, the all new system provides awesome performance. All enclosures are made from high quality MDF wood, with the satellites being finished in high gloss piano black. The subwoofer is fitted with a dual voicecoil reflex loaded woofer, and a high power amplifier that delivers superb bass definition. Edifier’s newly developed high performance tweeter with machined phase plug is fitted to enable incredible smoothness and wide dispersion for the satellites. Simply put, the new S330D Mediapro system will satisfy even the most ardent of audio enthusiasts.
Features
- 2.1 speaker system with 6.5 inch dual voicecoil subwoofer.
- High power BTL (Bridged Tied Load) amplifier delivers excellent dynamics.
- Wood MDF housings for all speaker enclosures ensure superb clarity.
- 2-way satellites with pro-designed crossovers and high gloss piano finish.
- High performance soft silk dome tweeter with phase plug for extra smooth wide response.
- Headphone output and auxiliary(AUX) input on wired remote controller.
- Subwoofer built-in Bass control.
- Unique Halo style design power indicator.
Specifications
- Power Output: RMS 18W x 2 + 36W (THD=10%)
- Signal to Noise Ratio: >=85dBA
- Amplifier Distortion: THD+N<0.5%
- Input Impendence: 10K Ohm
- Input Sensitivity: 400mv. (+/- 50mV)
- Frequency Respense: 55Hz - 20KHz
- Bass Unit: 6.5" (106mm), magnetically shielded, 4Ohm.
- Satellite Unit: 2" (78mm) mid-range and 3/4 inch silk dome tweeter, 4Ohm,magnetically shielded.
- Dimension: Subwoofer ---9.7"x9.7"x11.3" (246x246x286 mm) WxDxH, Satellites ---2.7"x7.5"x3.9" (68x190x100mm) WxDxH
- Gross Weight: approximately 19Lbs (8.6kg)
- Power Input: 220V-240V ~, 50/60Hz
** boxes opened to include UK power cable, 100% new **
Only £109.99 inc VAT.
ORDER NOW
Edifier S550 5.1 Speakers 280 W RMS Sound System @ £294.98 inc VAT
280 Watts of power drive this luxurious 5.1 system. Coupled with a passive radiator the massive 10" subwoofer driver provides a room-filling 120W of deep bass. A multi-functional 2.5" LCD display wired controller provides all the control any user needs.
Features
- Luxurious 5.1 speaker system with 10 inch subwoofer
- Wooden MDF housing for all speakers
- Passive radiator on both sides on the subwoofer to exaggerate bass performance
- Magnetically shielded drivers for all speakers
- Switchable dual input ports for both 5.1 channel and stereo inputs
- Multifunctional wired controller with 2.5 inch LCD display (dimmer included)
- Headphone output on wired remote controller
- Master volume controls both speaker output and headphone output
- Volume booster for extra power output
- Separate bass and treble adjustments
- Multifunctional wireless remote controller included
Specifications
- Power output: RMS 32Wx5 + 120W (THD=10%)
- Signal to noise ratio (amplifier): >=85dBA
- Input sensitivity: 5.1Ch: L/R: 480mV +/- 50mV SW: 175mV +/- 30mV Stereo: L/R: 520mV +/- 50mV SW: 200mV +/- 30mV
- Frequency response: L/R: 140Hz ~ 20kHz SW: 20Hz ~ 133Hz
- Bass Unit: 10", magnetically shielded speaker driver, 4Ohm.
- Satellite Unit: Mid-range ---- FR/FL/SR/SL: 3 1?2", magnetically shielded, 8Ohm C: 3 1?2", magnetically shielded, 4Ohm Tweeter unit--- 1" silk dome tweeter, magnetically shielded, 6Ohm
- Dimension: Subwoofer: 14.4"x15.6"x19.2" (367x397x489mm) WxHxD, Front speaker: 4.6"x8"x6.3" (116x203x160mm) WxHxD, Center speaker: 12.4"x4.6"x6.2" (316x117x157mm) WxHxD
- Gross Weight: approximately 82.5Lbs (37.4kg)
Only £294.98 inc VAT.
ORDER NOW
As you can see, a line in each category :)
One to look out for is the R1600T Plus. Any audio enthusiast will know that M-Audio, SAMSON and other well known manufacturers make some sublime Studio Monitors. Edifier after testing are at no exception to this rule. To take bookshelf speakers and add an amp powerful enough to power them one would think would cost a fair amount of money. This is certainly reflected in the price of the other brands but the Edifier honestly perform massively beyond expectations. The lack of a subwoofer is absolutely no issue as music production is absolutely perfect bettering pretty much any other set of 2.0 speakers and 2.1 speakers at the price point in terms of build and audio quality.
Looking for warm and precise music for well below £100?? Edifier R1600T Plus is certainly the answer!
I can't agree more on these, simply blown away by the quality of quality of the music these produce. Also they are in a wooden enclosure, no cheap plastic crap.
Do any of you guys have proper Hi-Fi gear to compare them to? The R1600T Plus are the only ones of interest really. They're pretty cheap for speakers+amp.
Indeed. The power output at 2x 16W may seem very little but these are TRUE 16W per channel speakers that easily out perform most of the 200W sets on the market which just goes to show that manufacturers clearly exaggerate ! Having an amp built in certainly de-clutters the desk so thats a massive bonus too! T20s and T40s have never had such a stomping!
I have mission and Kef mixed speakers with a yamaha AMP. Obviously when your talking about £1200+ worth of kit the Edifier is bound to be out performed however these are studio monitors designed for the studio. As such sound production is exceptional and the volume for the size is mind blowing.
You cannot buy an AMP and Speakers that match these in terms of quality for less than £200 so with that in mind they are VERY impressive!
What is the bass outpu like on those monitors? Considering getting some for my work on Reason :)
EDIT: just noticed they have extra inputs, can i add my x-240 Sub to them?
Any reason why you aren't stocking the Edifier Studio R1900 TII?
This is a possibility however the range is expanding gradually to see what sells and what doesn't.
These R1600Ts are by far the best "music" speakers we stock gaming though is an unknown.
The R1900 TII looks like it could also be a good little set so I shall have a look into getting some stock in :)
I honestly could not tell you if the sub could be added to these monitors but the base is very good, probably on par with the X-240 in all honesty in terms of volume but far superior in the frequency range they cover.
damn you andrew!! ive been waiting for the corsair sp2200 to come into stock to replace my celestion F1's and scythe kama amp (amazing set up but no real volume or bass).
but now you throw the rt1600 in the mix.
hmmmm choices choices.
Given a choice Id get these even if they were twice the price :)
im tempted very tempted!
but im trying to gain space on my desk so getting rid of my F1's to replace them with these is defeating the object.
any idea when the sp2200's are in?
They should be in in a couple of weeks.. There was around a month difference on release between the SP2500 and SP2200 so that would make sense.
How do the 2.1s compare to Aego Ms?
The prisma isn't quite there but for the size and the price it is exceptional value and with that in mind is a valid alternative. The 330D is just about on par but the solid quality of the aego ms would sway me. (and did :P)
I have a set of Edifier aurora speakers, a 2.1 set designed for use with notebooks (with the right cable lengths but still mains powered). They are really excellent little speakers, solidly built from aluminium, perhaps you should stock a few of them. They come in a wide range of colours too. I went for electric blue.
Is R1600T will be a good idea for general use with my PC - gaming, some music?
Now I have old Creative t5600 - will R1600T better for my use?
Music wise the R1600T is better than anything on the site as they literally are a dedicated set of bookshelf speakers. Games are also good but a good headset as you are aware cannot be beaten.
Aah might order these as soon as my netbook is sold :) will you be getting the Arctic Cooling Accelero Extreme 6950 cooler in stock as well? If so you may be taking even more of my money lol :)
