EGR valve on the vectra DIEsel - hard to fit?
18 Oct 2002
The remittance desk
Just a quick one, as per form, the EGR valve has packed in on my mate's vectra diesel. It's a 96 P plate and I'm hoping to help him out with one - anyone had to change one before?
Cheers
...and how do I do that???
Never worked on the vectra but ciew my mechanical intervention as..."It can't be that hard...?" and just get on with it!!!
Just had the valve out, looked ok and moved up and down with a fair bit of pressure. Gonna try the bypass, seems easy enough. Whilst it's bypassed I'll give the old EGR a clean in carb cleaner and see if that helps later.
Cheers boys
