Hi all - anyone here heard of voltage issues with the Asus aura headers and EK water blocks? I've finished my custom loop with all EK gear for Asus ROG XI Maximus Hero, and 2080Ti and used the water blocks for the board and GPU. Temps are good, and no leaks but the lighting isn't working on the Momentum block for the mobo & CPU. It was flashing a bit red or blue to start with but now won't work at all.
Everything is good with the GPU block so I swapped the GPU block over to that header and it worked just fine. Unplugged everything from Aura except the CPU/Mobo block and it still doesn't work. Even completely wiped the system and installed aura again (which is recognising the block but it just won't do anything).
I raised a support ticket with EK but they say I should just contact Asus as it's a voltage issue (and update the bios which was done already), but I can't believe as the other block works fine in that header.... any thoughts or are they just trying to pass the blame for a block with faulty lighting?
