EK pump 4.0 + Res combo strange noise?
Those are pretty good temps. I'm disappointed in mine, higher idle temp than my £5 air cooler and bsod under ibt.....I'm hoping I've not seated the cpu cooler tidy....will be really annoyed if it can't handle a basic overclock.
Water cooling only really pulls away in terms of performance at the higher end of temperature loads so I wouldn't worry too much about idle temperatures. My full loop is performing on par with the H100 I was using previously when at idle, give or take a couple of degrees. But.....My new loop mops the floor with the H100 when working heavy temp loads produced when over clocking.
Reseating the CPU block sounds like a good place to start, just in case that's the issue.
