A previous owner of our house had spotlights installed in the wall running up the stairs. They are controlled by a fused switch at the bottom of the stairs.
What is the best way to connect these to a smart home network? I was going to buy a normal smart wifi switch until I realised the existing one was fused. I cant seem to find a fused smart switch compatible with amazon echos online.
I think the lights are spurred off an existing power socket, if i turn the light circuit off in the CU i can still turn the lights on over the stairs.
TIA
TIA
