electrical question
If you look closely where it says Output 12v ~ 1.5A, the little ~ symbol means AC, if it was DC it would be a line with three short dashes underneath it.
Ah cheers, I have another router which does use a 12v DC input so I will use that.
What would actually happen if I tried to use an AC supply in a DC circuit and vice versa?
If you put AC into a DC device it will probably fry it, unless it has some sort of voltage protection diode in it. Mind you even then the diode would only last once.
DC into AC probably won't do anything but I wouldn't leave it to chance. Always make sure about the voltage, type of current and polarity.
I finished putting the radio together today and tested using my Linksys 12v DC adaptor, and it worked fine.
If anything, I'd expect the DC into AC to be more likely to work, as DC through a rectifier is still DC. AC into a DC device won't kill any diodes, but could end up being half wave rectified, I doubt the device would function though.
