** EPIC TUESDAY @ OCUK ** Cooling Products - IC Diamond @ 98p and MORE..... (ALL SOLD OUT!)
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
Getting warm in the summer? No problem!
IC Diamond 7-Carat Thermal Compound (1.5g) @ £0.98 inc VAT
IC Diamond out performs all other compounds in independent user testing amoung the popular brands tested, IC Diamond contains 92% pure syntheic Diamond. Purified synthetic diamond has a thermal conductivity of 2,000-2,500 W/mKL compared to 406-429 W/mK for pure silver. IC Diamond is electrically none-conductive and none-capacitive providing protection for electrical components when used.
IC Diamonds exceptional durability is due to its high bulk loading of micronized diamond particles. Each tube of IC Diamond contains over 92% micronized diamond and ais 94% fully loaded counting other miscellaneous particles. This highly loaded mix (90% + Bulk loading) is recommended by chip manufacturers to limit pump out due to thermal cycling.
IC Diamond is a stand out amonst all compounds by providing both high performance and long term reliability. Lightly loaded or creme type pastes initially provide some preformance, however the effect can be transitory, sometimes only lasterin a couple of weeks or months. You are safe in the knowledge that IC Diamond thermal conductivity lasts forever.
Based on Independent tests IC Diamond performs 2.77°C better than OCZ Freeze, 3.28°C better than Arctic Cooling MX-3, 3.38°C better than Arctic Silver 5 and 4.74°C better than the Intel generic paste.
- Each tube of IC Diamond Thermal grease contains 7 carats of micronized diamond with diamond particle loadings @ 94% by weight. Material loading above 90% is recommended as the best combination of rheological and thermal properties to minimize interface pump out due to thermal cycling.
- Superior bulk conductivity
- Excellent thermal impedance
- Tight particle distributions
- < 40 µ maximum particle diameter
- Silicone free
- Lower viscosity
- Greater stability
- Non capacitive or electrically conductive
Was £6.98 Inc. VAT
Only £0.98 inc VAT.
ORDER NOW - - (MAX 2 UNITS - IF YOU ORDER MORE THAN 2 UNITS YOUR ORDER WILL BE CANCELLED)
Antec Tri-Cool 3-Speed 120mm Fan - Black @ £SOLD OUT
No matter what type of fan you're looking for, the Antec TriCool line offers reliable, stable performance. Available in 80, 92, and 120mm, TriCool fans offer the perfect balance of silence and efficiency. TriCool fans feature a 3-speed switch so you can find the ideal equilibrium of quiet and cooling.
- 3-speed switch lets you balance quiet performance with maximum cooling
- 4-pin power connectors provide convenient connections to your motherboard or power supply
- Fan-speed monitoring capability included (requires compatible motherboard)
Was £2.99 Inc. VAT
Only SOLD OUT inc VAT.
ORDER NOW - (MAX 10 UNITS - IF YOU ORDER MORE THAN 10 UNITS YOUR ORDER WILL BE CANCELLED)
Corsair Hydro H50-1 High-Performance Liquid CPU Cooler (Socket LGA775/1155/1156/1366/AM2/AM3) @ £34.99 inc VAT
nonl2br
The Corsair Hydro Series™ H50 CPU Cooler gives you the power of liquid cooling in a compact, easy to install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
The Hydro Series H50 goes head-to-head with top of the line heatsinks, but maintains the near silence of liquid cooling for annoyance-free cooling performance. Due to its compact form factor, the H50 is the ideal solution for any case with a 120mm fan mount, even small form factor cases that prevent the installation of traditional heatpipe based air coolers. So whether you want world-class cooling, lower noise levels than your current CPU cooler, or something that fits in your small form factor case, the closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.<br><br>
- Pre-filled, closed-loop system is easy to install<br>
- Copper CPU cooling plate for maximum cooling performance<br>
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection<br>
- Large 120mm radiator for fast heat dispersion<br>
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator<br>
- Two-year warranty<br>
<br><br>
Was £50.99 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW - (MAX 2 UNITS - IF YOU ORDER MORE THAN 2 UNITS YOUR ORDER WILL BE CANCELLED)
Just ordered some of this goodness. I'm always in need of fans for new builds (I'm the family designated guru), so these'll definitely come in useful sooner rather than later. :)
great price on the ac diamond, and wow the h50 even cheaper, i almost feel cheated i paid £40 for it last week!
1 question as these deals are time/quantity dependant, if i continue to add things to my basket and then pay in one go later on today, will the items be guarenteed still at the reduced price?
ahh too tempted on the H50-1 :( why couldnt you do all of these closer to payday ... Just booked flights and hotels to thailand which cost me almost 2k :(
When is the use by date (if there is such a thing) for the IC diamond stuff?
It's a great price but I'm unlikely to use up what I've got this year.
Cheers
edit:answered cheers
god DAMN IT.. have to order fans and /ic /diamond now... :| stop posting these deals you !!!!!!!!!
