2004 Clio 182 on 60K miles
- Couple of door dings courtesy of the work car park - dent man coming on monday.
Looks perfect now!
Wheres the combustion soot going if its not trapped in the oil easily removed when you change the oil?
AC stuck ON (great in this weather, not good for MPG)
Rear washer not working
No screenwash left
Annoying bumper scratch
Creaky leather seat
Fog light bulb blown
Other than that the car is great for a 52 plate Mondeo 1.8
Though it does annoy me highly when refuelling, but I forget about near enough every other time. I asked the dealer for the rubber string bit for my filler cap, not available seperately and only comes with a new filler cap. At a cost of £20.
Not sure if I want to buy it, I'll feel like a pleb buying a filler cap just for a piece of rubber, but at the same time it'll ease my annoyance with it when I come to fuel up in future
Not sure if yours is the same but I have a small holder on the inside of the fuel flap that you can push the narrow end of your fuel cap into? Kind of makes the rubber hanger redundant which is why I'll probably never bother replacing mine.
My TS3 E46 330Ci Sport
- Driver window squeals on the rubber seal when going up or down. This is probably the most annoying! Any quick fixes for this?
Wipe the rubber seals down with IPA to get them properly clean, then rub some Gummiplfedge (sp?) onto them to get them nicely lubricated and not so dry.
Sit back and enjoy the silence of your super quiet windows
I got my Gummi from Euro Car Parts off the shelf so that's probably the easiest place to get hold of it.
I've got that too It's just the rubber strap being broken that's annoying more than anything else - must be my OCD
