EVGA SR-X
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
http://www.evga.com/articles/00668/
Chipset - Intel C606
SLI - 4-Way
SATA - Native 3/6G
SAS - Native 3G
Memory Support - 12 DIMM Quad-Channel DDR3 1600MHz+ (Up to 96GB)
PCI-E Slots - 7 PCI-E 3.0 16/8x slots
Capacitors - 100% POSCAP
Form Factor - HPTX
Ethernet - Gigabit Intel NIC
3x USB 2.0 Headers
1x USB 3.0 Headers
4x SATA 3G Ports
2x SATA 6G Ports
2x Mini SAS Ports
1x 1394b Firewire Header
4x Rear Panel USB 2.0 Ports
6x Rear Panel USB 3.0 Ports
8x Channel Audio + Optical
Dual Intel Gigabit Ethernet
2x E-SATA Ports
300% More Gold Content
2x6 Phase PWM
Onboard Bluetooth
PCI-E Disable Switches
E-LEET Tuning Utility Support
Triple BIOS Support
EZ Voltage Read Points
Onboard CPU Temp Monitor
Passive Chipset Heatsink
8+6PIN CPU Power
100% POSCAP Capacitors
DIMM Disable Switches
Chipset and Bus Details
The EVGA SR-X uses the Intel® C606 chipset. This chipset has native SATA 6G and SAS.
Only Xeon® E5 Class Socket 2011 CPUs are compatible. It IS NOT compatible with Core i5/Core i7 CPUs. Please visit our CPU Support Page for details.
The EVGA SR-X motherboard supports PCI-E 3.0 performance via a PLX PCI-E 3.0 certified bridge chip. This allows the SR-X to populate all PCI-E 3.0 slots at the maximum bandwidth possible. The PCI-E lane configuration is as follows:
1 Card: x16
2 Cards: x16 - x16
3 Cards: x16 - x16 - x16
4 Cards: x16 - x16 - x8 - x8
:eek::eek::eek:
This is the only board that would ever tempt me away from a Mac Pro.
I assume over clocking by the bclk multiplier is the only way here?
Edit: Nope. No BLCK straps and E5 Xeons are locked.
The whole thing seems a little pointless now :/
There must be (i hope) some unlocked 2011 Xeons coming soon, just a matter of time.
If you were Intel, why would you bother?
Xeons are for servers and workstations where stability is paramount. The amount of people who would buy SR-X type machines are very, very few in number.
Hence, I don't see it happening.
The best I recon will happen is BCLK multipliers.
Bit of a shame really but hey-ho.
Maybe some Extreme versions are based on Xeon? I don't know. There has been a load of unlocked Xeons in the past, so why not in the future?
Edit:
http://news.softpedia.com/news/Intel-May-Release-Unlocked-Xeon-E5-CPUs-in-2012-236174.shtml
Asus will also be bringing out their own Dual Socket 2011 board shortly. And unlike EVGA you shouldnt have any issues with getting hold of them.. :rolleyes:
the whole Xeon thing is the only thing concerning me
the overclockable nature of the last gen of westmere xeons was superb
my X5680 did 5GHz with ease in my X58UD7 board. but it does seem a little pointless.
that said, the features of the board do make up for it a little.
without clocking, i cant see it being much faster than an SR-2
