**EXPANSION OF MONITOR STAND RANGE!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK is now working with three manufacturers of monitor stands, Btech, Peerless and XFX. If you want a stand from these manufacturers or product, we can get it, just call our sales. We are holding the below products in stock as they are the most common and popular choices:-
B-TECH BT7332 AViBall Dual Monitor mount with Glass Base @ £73.99 inc VAT
Suitable for screens using 75mm x 75mm and 100mm x 100mm VESA mounting patterns. Designed to hold 2 screens upto 22" Widescreen (Max 15kg per screen). This comes with a glass base and provides a stylish storage area. Easy tilt and swivel adjustment 37° in any direction.
- Suitable for screens using 50 x 50mm, 75 x 75mm and 100 x 100mm VESA mounting patterns.
- Designed to hold 2 screens up to 22" Widescreen (Max 15kg per screen)
- Glass base provides a stylish storage area under the screen to hold a keyboard when not in use.
- Lateral screen adjustment along horizontal rail for optimum screen positioning.
- Easy tilt and swivel adjustment 37° in any direction
- Base made from 10mm (0.4") thick, tempered safety glass with non slip rubber feet.
- Cable management and pole end ring included for smart installation.
- All fixings included
Only £73.99 inc VAT.
ORDER NOW
B-TECH BT7333 AViBALL Triple Monitor mount with Glass Base @ £99.95 inc VAT
The glass base is designed to hold a keyboard on top when not in use to keep the workspace tidy
The position of the flat screens can be adjusted along the horizontal bar
B-TECH AViBALL BT7333 - Mounting kit ( desk mount ) for 3 LCD displays ( Tilt & Swivel ) - screen size: 22" - mounting interface: 100 x 100 mm, 75 x 75 mm
- Designed to hold 3 screens up to 22" Widescreen (Max 15kg per screen)
- Base and Arms are black
- All Fixings Included
Only £99.95 inc VAT.
ORDER NOW
Peerless Single Arm Desktop Mount for Single 12-30" Monitor (black) @ £71.99 inc VAT
Increase productivity by freeing up desk space with more efficient display positioning. The 420A series is a single display mount with a flexible arm, and includes a grommet and desktop clamp mount solution. Installation is quick and easy, and secures a display with a quick release mechanism. Instantly set the height of a display by raising or lowering it 12.6" and tilting it forward and back. Furthermore, the LCT420A can pan and rotate for a comfortable portrait or landscape viewing.
Features:-
- Desk clamp and grommet mount option
- Tilt: -80/+20; Pan/Swivel: 270°; Rotate: 360°
- Compatible with VESA 75/100
- Portrait or landscape without removing the display
- Arm extends up to 16.4" with 12.6" of height adjustment
- Can be used in laptop configuration with ACC329
- Internal cable management to keep cords out of the way
Limited 5 year warranty; Peerless will repair or replace, or refund the purchase price of, any product which fails to conform with this warranty.
Only £71.99 inc VAT.
ORDER NOW
Peerless Dual Arm Desktop Mount for Twin 12-30" Monitors (black) @ £149.99 inc VAT
Increase productivity by freeing up desk space with more efficient display positioning. The 620AD series is a dual display mount with flexible articulating arms, and includes a grommet and desktop clamp mount solution. Installation is quick and easy, and secures a display with a quick release mechanism. Instantly set the height of the displays by raising or lowering 12.6", extending up to 22", and tilting forward and back. Furthermore, the LCT620AD can pan and rotate for a comfortable portrait or landscape viewing.
Features:-
- Allows flat panel display to configure side by side or back to back
- Arm extends up to 22" with 12.6" of height adjustment
- Independent tension adjustment in the arm and mount
- Arm folds back over the base into a compact retracted position
- Limited 5 year warranty; Peerless will repair or replace, or refund the purchase price of, any product which fails to conform with this warranty.
Only £149.99 inc VAT.
ORDER NOW
Peerless Dual-Monitor Desktop Mount For 20" to 30" Flat Panel Displays @ £99.95 inc VAT
This beautiful sleek desk top stand raises two monitor off the desk surface, thus saving workspace and creating a productive monitor configuration to increase productivity. Adjust the height and position the monitors to the ideal viewing point. It is quick and simple with the adjustable locking system which allows it to move and lock the monitors freely along the vertical rail without using any tools.
Features:-
- Supports two up to 30" displays on a 35.4" crossbar , thus saving workspace
- Easy to assemble and requires 2 square feet of desktop space
- 12" of height adjustment for the ideal viewing point and 5.3" distance from the vertical rail
- 75 and 100 VESA mounting pattern
- Adjustable mount locking system allows it to quickly move and lock displays freely along the vertical rail without using any tools.
- Thread cables along the horizontal crossbar keeping cables and cords out of sight and protected
ORDER NOW
Peerless Desktop Mount for Triple 14-24" Monitors - Black @ £143.99 inc VAT
This beautiful sleek desk top stand raises two monitor off the desk surface, thus saving workspace and creating a productive monitor configuration to increase productivity. Adjust the height and position the monitors to the ideal viewing point. It is quick and simple with the adjustable locking system which allows to move and lock the monitors freely along the vertical rail without using any tools.
Features:-
- Supports three 19" displays on a 35.4" crossbar , thus saving workspace
- Adjustable mount locking system allows to quickly move and lock displays freely along the vertical rail without using any tools.
Only £143.99 inc VAT.
ORDER NOW
Peerless Desktop Mount for Quad 20-30" Monitors - Black @ £179.99 inc VAT
Features:-
- Supports four 30" displays on two 35.4" (900mm) crossbars, thus saving workspace
- Easy to assemble and requires a minimal amount of desktop space
- 24" (609mm) of height adjustment for the ideal viewing point and 5.3" (134mm) distance from the vertical rail
Only £179.99 inc VAT.
ORDER NOW
XFX Triple Display Monitor Stand @ £299.99 inc VAT
XFX’s Triple Display Monitor Stand is specially designed to withstand the most intense gaming sessions as well as extreme work days. The XFX Triple Display Monitor Stand is fully adjustable. Monitors can be arranged individually or collectively up to 24 inches each, for height, angle and rotation.
The XFX Triple Display Monitor Stand’s single base frees up desk space while the integrated cable management keeps cords organized and untangled.
Adding functionality to sleek design, the XFX Triple Display Monitor Stand also features two USB ports as well as jacks for your gaming headset.
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience .
Features:-
- AMD Eyefinity Ready
- Custom XFX styling and design base
- Two front facing USB ports and audio ports
- Cable Management
- Adjustable mounting brackets
KitGuru's Review:-
The XFX Eyefinity Stand is going to be popular with the gaming audience who want to regain some deskspace. The screens can be rotated, tilted and adjusted for height, on both vertical and horizontal axis, meaning that a fine level of adjustment is possible.
As an aesthetic centerpiece, it is certainly worth an investment, especially if you are unhappy with the positioning of your panels. We really like that the screens can be rotated into portrait mode with the XFX stand, as not every native monitor stand allows for this kind of adjustment.
I also have no issues with the build quality, as every component has been carefully engineered to deal with a substantial amount of weight, from the center point, to the extremities of the horizontal bars. If XFX had cut corners with the engineering standards or quality of materials, this could easily have ended up a dangerous piece of equipment. Also, it is worth mentioning that with three monitors attached, and with the weight of the metal skeleton frame, it can indeed be difficult to move without some help.
Highlighting the excellent build quality, we even managed to fit a 27 inch in the middle position without any concerns, although XFX don't offically recommend sizes larger than 24 inch. We also like that the small touches haven't been overlooked, such as a rubber mounted pad underneath the main base plate to stop it moving, and to ensure no scratches on wooden surfaces.
Only £299.99 inc VAT.
ORDER NOW
You can now setup your dream monitor Eye-Infinity/NV Surround setup. :D :D :D
Although I wont be buying one (already have 3 monitor arms) I do applaud the decision to sell these. Plenty of people looking for affordable monitor stands/arms. The XFX doesn't really fall in that category but cant blame OC UK for XFXs excessive pricing.
Is it just me or does the xfx stand look like a fighter jet spreading its legs? Especially considering where you plug your jack in ;)
I would like the dual peerless arm mount though. Very sexy indeed.
Any reviews on the 3 monitor peerless? I'm considering purchasing another 2 U2412Ms and was wondering whether this stand would be enough to hold them securely.
Can someone confirm that the triple mount description is correct? It says 3x14-24 monitors in the title but 3x19 in the description. It says 3x19 on the Peerless web site as well. Can someone confirm that this will actually do 3 x 24" monitors?
