*** Expensive Case an Ideal Christmas Gift***
7 Feb 2011
Stoke on Toast
Struggling on gift ideas for Christmas well here at OcUK we are always striving to provide you with all the options and today is no different for Today we bring you the Thermaltake Level 10 Titanium edition limited to 500 Units world wide this glorious metal monster will make you the envy of all at Lan with it's look at me curves and flashy grills. So go one brighten up your or someone elses life with some Designed metallic surfaces in your office
HO HO HO
Thermaltake Level 10 Titanium Limited Edition @ £899.99 inc VAT
The “Level 10” concept allows gamers to experience the power of their high-end computers through the design itself. In order to achieve this, iconic design is combined with optimum functionality and innovative details. By rendering the inside components visible, the design concept focuses on the architectural aesthetics which are inherent in the computers and result from each individually configurable component. The inspiration for this approach the design team took right from the computer worlds themselves – expressiveness, virtual townscapes and futuristic game components served as orientation for the arrangement and the look of individual components.
Specifications:-
- Dimensions: 318 x 666.3 x 614 mm (W x H x D)
- Material: aluminum
- Weight: 21.37 kg
- Color: Titanium, Black
- Format: ATX, Micro-ATX, Mini-ITX
- Fan:
- 1x 140 mm (front, 16 dB (A), 1.000 U / min, red LEDs)
- 1x 120 mm (rear panel, 16 dB (A), 1.000 U / min, red LEDs)
- 2x 60 mm (HDD, 19 dB (A), 2,500 U / min)
- 1x 120 mm (front, optionally, instead of 1x 140 mm)
- Bays:
- 3x 5.25 inch (external)
- 6x 3.5 / 2.5 inch (internal))
- AC adapter (optional): Standard ATX
- Expansion Slots: 8
- I / O Panel:
- 4x USB 3.0 (internal connection)
- 1x eSATA
- 1x per Audio In / Out
Only £899.99 inc VAT.
ORDER NOW
Aside from the obvious looks and practicality (and price) it definitely seems a throw-back to a time before solid state drives with that number of drive bays.
Does anyone still run with that many BD/DVD/CD and hard disk drives?
And I thought £200 for a case was expensive :eek:
Do like the look but a bit too costly for the likes of me - will stick to Corsair for now:)
Imagine trying to carry it to a LAN
Has a user friendly handle :D
On a serious note I think it looks amazing but it's mental.
once you add 3 980's a 1300W psu a couple of HDD some SSD a DVD drive and a cooler you're easily looking at 30+ kg :D
LOL, now we know the secret to 8 Pack's workout... :D
I hope you didn't buy all 500 units! Can't see many of these shifting for that price. Sure it looks nice, but for that price you could have someone custom make you something much more delicious.
It's not an OcUK exclusive and we aren't silly but we will sell a couple we always do.
