What are the best fans to use on a both single and dual H50 configuration mounted verticaly in a Silverstone RV02?
I imagine the best solution is to have the top fan will be blowing air out of the case and the bottom fan pulling it upwards but do either of the fans need to be high static and if so which are the best quiet high static fans?
And if I just install a single fan would I have the fan mounted on top exhausting air out of the case and the radiator mounted underneath it?
Thanks.
Thanks.
