I'm after a fan controller that fits into a 5.25 bay and also mounts the Hard Drive, something similar to say...the Coolermaster Cooldrive's, I don't want the fan's to be software controlled though, a simple rheostat style would be ideal. Also, I'd prefer it to look as plain as possible.
I fitted a couple of 38mm Panaflo FBA12G12L's over the weekend as I wanted the option of something with greater airflow than the Yate's i've used up until now. They've shaved 10degrees off the load temp I was getting previously in Orthos but are too noisy for anything (other than benching) at 12v and a little weedy at 7v.
I've only got 1 5.25" spare and need to mount both in the one bay...any ideas?
Thanks in advance!
Thanks in advance!
