I've just plugged my two case fans into the fan controller of my 600T.
I don't really see much of an effect when I increase the fan speed. The LED glows a little brighter and I hear a bit more noise but I only notice a small increase from lowest to highest setting. Is this correct ?
How do I know if it's working correctly ?
Also if the fans are plugged into the fan controller how can the MB monitor the speed of the fans ? Surely they need to be connected directly to the MB ?
Cheers
J
Cheers
J
