Fan Filters - Is it Worth it?
I would say you definately need dust filters. They are essential for any rig. If you don't have them then the cpu and/or gpu fan will eventually get dust blocking the air channels in the heatsink and will cause temps to rise. Plus dust makes a mess in your case.
I used to have CM Scout. A lot of dust are trapped in the front mesh cover with dust filter. Inside the case was very clean. So I think it's pretty effective.
