hi, my issuse is how the hell do you stop the fan running full speed? 1695RPM
only way i can get it to shut up is installing a fan control. i do not overclock, everything in bios is as i just got it.
temps are good 27/32 idle Room Temp 24c
i use the Corsair H50 with stock Fan. And it loud!!! running at full speed?
is there anything i can do in Win7 64bit to lower the speed or noise? sounds like a Xbox360 lol
EasyTune 6 or Speedfan dont work, not sure why. just dont load up.
so any hep would be great, because The Sound is annoying the HELL OUT ME!!
much Thanks.
p.s sorry if this is the wrong section.
Intel Core i7 920 D0 + Gigabyte GA-EX58-UD5
much Thanks.
