Faulty goods from spares place, advice on rights please?
22 Dec 2002
Minehead
Hello all,
My friend sourced a box for his coupe turbo to replace the current one (bearings had failed) and was going to get around (dreckly) to getting the old box reconditioned. The new box we found online, gauranteed and tried and tested. :rolleyes:
Anyhows long story short, he had the box fitted by a garage and its awful. Pops out of second whines and makes thrust bearing like noises with the clutch out, only it isnt as its had a new clutch kit (so I'm assuming the input shaft//bearings are also gone?)
What rights does my friend have with regards to a refund as they've said they can't source another one. Would they just give him a refund and expect him to get the box taken out? It cost a fair whack so understandably he's annoyed when quite obviously this box wasn't tried or tested at all.
Sorry for the long read and thanks very much for any help :)
Mike
-Mike- said:
...and makes thrust bearing like noises with the clutch out, only it isnt as its had a new clutch kit (so I'm assuming the input shaft//bearings are also gone?)
That will be the idler gear bearings.
Not sure about the law regarding things like this, but you are still covered by the sale of goods act so might be worth a read of that.
Cheers for the reply mate, shall have a read after I get back from a mechanics place to see how soon he can recondition his old box!!
I've had a very similar problem. Had a reconditioned gearbox which had not been put together properly. Neutral was a reverse gear :rolleyes:
Asked for a refund, they wanted to collect it to make sure it was faulty, and they never did come after about 8 different tries.
Had to goto court in the end to get a refund :(
Burnsy
This is why I would only ever trust a known good source for gearbox repairs - ask on relevant forums for a decent rebuilder and get the existing one done - it's known what current problems are so when it goes for rebuild you can spec the problems and ask to see all the replaced bits.
Awesome, thanks very much for the reply :) I sourced all the required bearings to rebuild his old box yesterday, he doesn't want the risk of getting another duff box and paying for it to be fitted!
If you're getting a chargeback the good must also be returned btw. Just in case you're thinking of doing a repair.
Burnsy
No not doing a repair, his old box has the correct gear ratios and correct speedo drive. It also has iirc the better diff so all should be pretty :) - The company have said they will arrange for someone to come and collect the faulty box once its removed.
