Hi,
I have currentley got a e6300 being cooled by a AC pro7 using the paste with come with the AC pro7. I just tested my system with the pro7 to see what temps were like. I just want to know what you guys think is a acceptable temp for a stock e6300 running 24/7. Used orthos to test the cpu (both cores) at 100% usage. And coretemp to read temps. And easytune5 to check fan speed. Temps are as followed.
33c @ 2800RMP idle.
48c @ 2800RMP load.
40c @ 500 RPM idle.
51c @ 900 RMP load.
Running at 2800 was very loud. Where as under 1000RMP was silent. I want to be running this pc 24/7 will these temps be acceptable ?.... also how much overclocking possability may i have with this cooler. Should be getting AS5 when i order media case ect off ocuk before christmas
33c @ 2800RMP idle.
48c @ 2800RMP load.
40c @ 500 RPM idle.
51c @ 900 RMP load.
