Hi all, I am using MediaPortal for my HTPC, and have some uncompressed DVD mpegs with both AC3 and DTS audio. I suppose this should also apply in MediaPlayerClassic since the codecs are used for both.
Is it possible to make FFDShow choose the DTS over AC3 where available ?
Anyone any ideas ?
Im NOT using AC3Filter or SPDIFer at the moment, as everything seems to go **** up when i try to use them, and apart from this, its working as I want it to at the moment. Though Im not averse to if required.
Thanks
Anyone any ideas ?
Thanks
