Hi all,
One of the front calipers has seized on our Fiesta Mk5 1.25.
I will call around various suppliers tomorrow but just wondering what you would do.
Would you repair them? Replace them? New or Refurbished?
Which suppliers would you recommend and any idea on cost?
The discs and pads were replaced last year, the seized wheel got quite hot so possibly the pads have got very hot too. What's the test to see if the pads are ok? If they're not OK, are they only fit for the bin?
Also, the flexi brake hoses need replacing so will do these at the same time. Where is best for these?
Ideally would like to get the parts tomorrow and can then work on the car over the weekend.
Thanks.
Thanks.
