First pc build
6 Feb 2021
Hi, New to pc building just wanted to know if my spec is compatible and would be good
AMD Radeon RX6800
AMD Ryzen 7 5800x
icue h100i elite capellix cpu cooler
Spectrix D60B 16GB RAM
Spectrix S40G 1TB ssd
B450 aorus pro mini itx am4
Mb320l case
MWE gold 750w fully modular atx power supply
thanks
23 Mar 2011
West Side
6 Feb 2021
Thanks again, this is the message “Warning!Some AMD B550 chipset motherboards may need a BIOS update prior to using Vermeer CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions” not sure what this means
Underboss
9 Nov 2005
manchester,uk
All B550 boards might need a bios update to work with Ryzen 5000, but a lot of them have bios flashback, so you can update without a cpu. The B550M Mortar mentioned above has this feature so there should be no issue.
6 Feb 2021
As stated above the case will take a matx board, the b450 itx board only has one nvme slot and pcie 3. This is a similar price to your selection and b550, it reviews well ▷ MSI B550M PRO-VDH WiFi (AMD AM4) B550 Micro-A… | OcUK (overclockers.co.uk)
https://youtu.be/Qf0-JoQLeJo?t=723
If you want to spend more on your board then as above the mortar is good
Thanks for the advice, I don’t really have a problem spending an extra £50 or so on the mortar as long as it is comparible
