Hey all,
We've reached the point of needing a server cabinet for the home. I've never purchased a rack/cabinet before, so apologise for the nooby questions! I'm just looking for some pointers and suggestions.
The largest thing to go in the cabinet will be a HP DL380 G6. It measures in at 690mm in depth (if I include the rails which stick out from the back a bit, it's 750mm in depth).
Because this particular server is so large, I'm not quite sure on what dimensions to go for on the cabinet. I've been looking at a 800mm depth cabinet, but noticed the description read "The internal racking depth is 130mm less than the external depth."
What width/depth should I be going for? And does anyone have any recommendations for a cab? I'm looking for a 21U.
Side Question: The house is currently being cabled with Cat6a, do I specifically need a Cat6a patch panel, i.e. if I grabbed a generic RJ45 patch panel, even if it was marked at Cat5, this shouldn't cause any issues?
