I don't think a "small filter" would have made any difference, you would have had to have some massive filtration system on a 75L tank with even 1 single koi! Also it would have had to be cycled before use.
10 inch Koi in a 75 litre tank? Are you sure it was as small as 75 litres?
50cm by 50cm by 30cm, thats 75 litres right?
A 10 inch Koi could barely turn around in that.
750litre maybe?
ere using a large 75 letre tank with lots of different foam, lava rocks, stones etc, which is a bio-filter tried and tested, but as it is set into the ground on the same level as the pond, we couldn't use it for the tank.
I think yu'll find he is using the 75l tank as a custom filter, if you read the post properly...
Ammonia poisoning ftw.
One of the first things you should know about about fishkeeping.
