1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Ford Focus Oil
Discussion in 'Motors' started by joey1211, 28 Dec 2017.
  1. joey1211
    Mobster
  2. Gaygle
    Capodecina
    One's a 5w30 and one's a 5w40? The 5w40 one isn't approved for Ford engines, whereas the 5w30 one is. I've never owned a Ford, but they always seem to have their own oil approvals and oil companies make a different product for them.
    What year/generation is your car?
    TLDR - go with the one which is approved for your engine.
  3. Armageus
    Don
    Firstly they aren't the same grade, the second is 5w40.
    Even if they were the same base grade, the ford specific one meets fords specifications e.g. may contain different additives
  4. joey1211
    Mobster
    Reading error on my part. Close thread! :o
  5. joey1211
    Mobster
  6. Gaygle
    Capodecina
    Get fully synthetic. There's literally no need to use semi synth oils these days.
    You can easily get 5 litres of full synthetic Ford approved oil for around £20.
    EDIT: Hell, that fully synth 5litre bottle of Ford approved TripleQX stuff is only £20!
  7. joey1211
    Mobster
    Ordered two fully synth.
  8. Mrjobby
    Hitman
    Just ordered a few cans of some Helix full Synth for my servicing 1.8 Dagdag Mondeo, came in at £15 a 5 litre bottle with the sale and discount code.
  9. Hyburnate
    Capodecina
    :o That’s dirt cheap
  10. Nasher
    Capodecina
    You need it to be the minimum spec or above for your engine. Never use cheap/crap oils.
    Stick with the OEM stuff unless you know what your putting in is the same or better. Engines get tested for millions of miles on that specific blend of oil, so you know it's good.
  11. Acme
    Caporegime
    I still use semi synthetic in cars with older engines such as my E30.
    Something about it being less harsh on old oil seals etc or something?
    Starting to wonder if its BS so I'm re-researching now... :p
  12. Nasher
    Capodecina
    I don't think there is much point in using anything other than synthetic now. Synthetic has just become better all round.
